hastagrevesz
Hi folks
I have an issue with my 1995 Golf MK3 1.9 Tdi 1z engine (manual). It's cutting out at random RPMs, more often at lower range, but not only. It does it mostly at operating temperature, but sometimes already at 70°c. It feels like engine breaking, like it is not able to make power. Sometimes it just jerks on the car and still excelerates in short bursts of power, sometimes it needs an RPM change an then its back to normal.
VCDS tells me no fault codes. Start of injection timing is spot on.
I have recently reseated the valves, had the turbo remanufactured (Tho they did not change the wastegate), and cleaned the injectors. Thats when the problem arous.
I have since doublechecked the timing, changed the turbo pressure regulator, the crank position sensor, and reset the fuelpump pressure relief valve. All to no avail.
Have anyone had the seame issue? Thanx in advance!
