SilverGolf19
I bought this Golf 3 months ago - it's 2011 1.6TDI
On startup it seems like it's missing but eventually clears up. Power is perfect but clinks and clanks when it's under load.
I've taken the injectors to a professional tester - whilst the injectors were ok, I was advised to swap out one injector (cost £520 for a new injector).
So far I've spent $1200 on changing the injector rail & new injector. It's made no difference. The garage had a VDCS but were unable to carryout Minimum Deviation setting.
I've had the fuel filter changed - there were no metal fillings (to eliminated a failing high pressure fuel pump)
I'm so frustrated, I bought a VDC for £500 to check myself.
On VCDS Auto Scan - I noticed 19 CAN GATEWAY status Malfunction 0010 error.
My question is that - "Would the CAN Gateway malfunction stop VCDS running Minimum Deviation calibrations"
