cdi320
As the title states, has anyone used the GM syncromesh manual transmission fluid in a 6 speed 02M/02Q? I read a long time ago on here people recommending the syncromesh for the 5 speed 02J manual, if you had notchy gears/grinding in any gear. To my surprise, I've used the syncromesh in two mk4 tdis, and it did wonders, including getting rid of a 3rd gear grind, which I did not expect, so I'm wondering if the same would happen with a 6 speed?
I don't have any gear grind on my mk6, but getting into gear is very notchy, especially second, and I did a fluid flush not long ago, maybe 25k miles, and put in liqui moly 75W, which I'm not impressed with
Reference for oil currently in gearbox
www.liqui-moly.com
Top Tec MTF 5100 SAE 75W
Low-viscosity high-performance transmission fluid. High shear stability provides low fuel consumption and excellent wear protection. Outstanding resistance to viscosity breakdown provides superior shift performance in all operating conditions. Suitable for a variety of transmissions.
