Cha2ga
Jimbote can you elaborate on Pennzoil Synchromesh vs GM friction modified Syncromesh?
nope...I only use the pennzoil stuff and have not seen the need for friction modified GMJimbote can you elaborate on Pennzoil Synchromesh vs GM friction modified Syncromesh?
there is nothing special about "our.. transmissions" sychromesh is made for transaxles (we have transaxles) with brass synchros (we have brass synchros )
there is a thread iirc by "bob is the oil guy" that discusses synchromesh gl4 compatability ... i'm right at 60k miles on pennzoil synchromesh in my 05' golf with 358k + miles ... it had a pretty nasty second gear grind after changing out the oem stuff for new OEM G07, s'mesh completely cured the grind within a half mile ... imo OEM fluid is inferior and i won't use it in any gearbox with yellow synchros period ...
Yup, that's the stuff.
-J
I was planning on getting mine from Amazon. SynchromeshI went to GM today and gave the part number listed on this thread for the pennzoil synchromesh fluid and they gave me a ACDelco blue and black bottle that says synchromesh transmission fluid and part number 89021808
is this the right stuff?
Save it for your next transmission flush...So what am I supposed to do with the leftover 0.9 quarts of gear lube after purchasing 3 quarts of Syncromesh to fill the gear box? LOL
Put it in your tank,So what am I supposed to do with the leftover 0.9 quarts of gear lube after purchasing 3 quarts of Syncromesh to fill the gear box? LOL
I'm going to change my trans fluid does anyone know if there is a difference between these two? if so which is better? if it doesn't matter i can get the napa stuff in town otherwise i have to order online... thanks!
https://www.autozone.com/motor-oil-...ission-fluid-1-quart/265000_0_0?checkfit=true
https://www.napaonline.com/en/p/PZE3501
ok, i just didn't know if there was a difference. The all yellow one has a gl3 rating (i read they needed gl4), and idk about the yellow and black bottle. i read of someone using the yellow and black bottle tho....Synchromesh is synchromesh, AC Delco or Pennzoil are all the same.
