queek
Or Turbo Diesel - you bring up an important point about insuring converted vehicles. I'll will have to switch from Geico - at least in NJ they don't insure modified cars.
I had this very discouraging experience yesterday: when I tried to fill the tank, the fuel went down the filler neck and then a moment later it was as if some pressure blew half of it back out - in NJ you can't pump your own fuel and the guy pumping the fuel was pissed after this happen three times and refused to pump any more. I managed to get 1-1/2 gallons into the tank. It works if I slowly pour the fuel in using a fuel can. The tank has a separate filler neck that has a check ball where it connects to the tank that might be restricting the heavier diesel oil, but to take it apart requires dropping the rear end down to lower the fuel tank...
Anyone have any ideas?
One thing I would have done differently was to follow my instincts and gone with a lower (numerically higher) final drive ratio and a .658 5th. While the TDI Gear is great for keeping the revs down, 1st and 2nd are pretty anemic until I get over 1500rpm with the added weight of the AWD drivetrain.
