2004 Jetta glow plug issues
Hello everyone. I am in need of some help trying to figure out my glow plug issue on my 04 Jetta. First off, ive been all over the internet trying to find anything helpful, and this forum site has been the most help with information, procedures and fellow owner advice.
I do not have a CEL. The glow plug circuit seems to be intact. The harness is good, the fuses and connections are all clean with no corrosion. The glow plug harness is also clean with no corrosion. When I cycle the key, the glow plug light comes on for 1-2 seconds and goes out. Ive disconned, inspected and cleaned the coolant temp sensor connector. With it disconnected the light will stay on for 3-4 seconds. All 4 glow plugs are reading .2 ohms and are new. Voltage readings at all glow plug connections is only reaching 7.84 volts before the system cycles off. I disconnected the relay and did get a CEL. Sooo I figured I had a bad relay Replaced the relay and still have all the same results... I’m at a loss now, and am not sure where to go next. Closest dealer to me is 360 miles away. I should mention that my car is a manual transmission car. The coolant glow plugs appear ok, but since I understand they aren’t monitored by the ECM, I haven’t spent much time on them... anyone have a similar experience, or know where I need to go next? Thanks sooo much for all the help and information so far....
