Glow plug problem
Cbub
Dublin
2000 jetta
My 2000 tdi jetta keeps throwing a code glow plug not working.i have replace all glow plugs wiring and relay module on coolant and engine. Code is po380
Curious Chris
Pineview GA
Jetta Wagon 2003 RIP Rockford IL
16764/P0380/000869 - Glow Plug/Heater (Q6) Circuit: Malfunction
Possible Symptoms
  • No Pre-Glow Period
  • Poor Cold Starting
Possible Causes
  • Glow Plug Wiring faulty
  • Glow Plug faulty
Possible Solutions
  • Check Glow Plug Wiring
  • Check Glow Plug
Special Notes
wonneber
Monroe, NY, USA
When you turn the key on does the glow plug light on the dash come on, even for a second?
Your Dublin 2000 may be different then what we have on this side of the pond.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
For some odd reason the glow plug codes need to be cleared with a suitable OBDII device like VCDS.
mittzlepick
union maine
2004 jetta wagon (365k)2001 wagon tire burner 6spd 2003 wagon(417k)
Tested it all with meter? Was it a short or long wire harness? Maybe a bit of differential in your crimp if it is a shorty, or a bad new gp. Test individual resistance and continuity in them and the harness. Being a 2000 its a two wire yes? Dodgy parts?
