Denver_Diesel
2000 Jetta TDI manual
Here's an interesting situation. I've searched the forums and can't find a similar instance. I recently had my timing belt replaced by Andersen Automotive in Golden, CO - along with the tires, engine oil and other fluids (it was a heavy maintenance cycle - i wasn't motivated enough to do it myself).
Anyway, before taking it in I got to know the car quite well, obviously. Upon starting the ignition sequence the behavior of the glow plugs as indicated by the dashboard light in the instrument cluster was this: The glow plugs would stay on for a length of time inversely proportional to the outside air temperature. That is, the colder it is outside (assuming the car has not been running in the last several hours), the longer the glow plugs stayed on. This makes perfect sense, and the best I could tell the relationship was linear. A rough approximation is that if it was freezing (0 deg. C) the plugs would stay lit for inbetween 3 and 4 seconds. If it was pretty hot outside (say 40 deg C) then the lights would stay on for less than a second. You get the idea. Ok, now for the interesting thing. Since the TB was changed, the glow plug lights have no temperature dependence. Regardless of the temp. of the engine block, they stay on for less than a second every time. Any insight for me??
thanks
thanks
