smokedvw
I've been having some rough idel and hard starts on the below freezing temperatures here in Canada . I know in my 2002 Jetta tdi 1.9l that usually meant time to replace the glow plugs.
I have a 2005 passat b5 (or 5.5) 2.0 l. The local shops were unable to find glow plugs to match the 2.0 but had ones to match the 1.9.
I finally pulled them and the part numbers do not match nor does the voltage. I'm car borsch are 5v, replacement ate 12v.
Does this mean I'm still running the old ceramic plugs? I read or warranty recalls replacing the ceramic with steel and different voltage.
This look like the proper replacement https://germanparts.ca/parts/n10591607-0250402004-genuine-oe-diesel-glow-plug/
Vs
These are what I got from lordco
Looking to understand if I should replace with ceramic again or do I need yo take it to a shop and have it switched to 12v steel and reprogrammed?
Thank you
Vs
Thank you
