Like many of you here I had the check engine light on my 98 TDI and went down to Autozone and got a P0380 code (the dealer wanted $78 to read it!). I figured I'd with the most likely (and cheapest) fix and got the glow plug harness. It was quite easy to pop the harness ends off the glow plugs. But when you get to where the harness wiring goes into the large round electrical connector there is a definite issue. How on earth does the electrical connector come off? When you look at the ends of the new harness there are male plugs with a nice rubber seal behind them, which suggests to me there should be a way to open the connector up and swap in the new plugs. My dealer says I should just cut the old harness wires and attach the new plugs to them. Can someone tell me what the secret to opening up the connector is?
Thanks.
Thanks.
