JeffT
- Joined
- Oct 4, 1999
- Location
- Diesel is diesel is diesel!
Listen there are 2 types of torque converters, the old style, the kind that don't lock-up and the kind that do.
The old kind that don't lock-up don't suffer from any REAL loss in MPG from the lock-up kind. The kind that do lock-up and then for some reason fail to lock-up will slip a hell of a lot more than the older style converters do. A lock-up converter that fails to lock up will reduce MPG in a car.
As I stated before, and as Fritz stated: "VW says that TCL (torque converter lock) is utilized for the purpose of lowering transmission operating temperatures. A slight increase of fuel economy if (sic) of secondary significance."
This IS the case. Automatic transmissions are more reliable than they used to be due to the lock-up converter, but it doesn't increase MPG. THE LOCKUP CONVERTER WASN"T DEVELOPED TO INCREASE MILEAGE. Any claims by the automakers to the contrary are simple puffery. There is probably a very small increase that they are hanging their hats on, but a non-lockup torque converter will give you the same MPG and better 0-60 performance than will a lockup converter, everything else equal.
