redbarron55
I have a Brake Ware light and it has been a while since the brakes were done by the PO (dealer done).
I assume that the dealer (Jim Ellis - Atlanta) changed the rotors and pads as this is the more expensive way to do it.
I bought the car used (VW recall) with 94,000 miles and the Carfax said the brakes were done at 74,000 miles.
I have bought the rotors and pads and fluid for a flush from ID Parts and have had then in their boxes until the pads were worn a little bit more that when we first got the warnings.
My question after this long prolog is the rear parking brake and the settings or the not setting.
I read that the ID of the parking brake is close to the original size as there is little breaking accomplished by the parking brake.
So the idea is that if you remove the rotors with the brakes released you can just swap the rotors and the settings will be good.
Is this correct?
I don't know what the ID is or the ! OD of the shoes. I have a 6" dial calipers if that would be large enough to measure, if anyone knows the size of these brake parts.
Thanks for any advice available.
Is this correct?
