Getting a TB Service Next Year - What else should be replaced?
Analogeezer
Northern Virginia
2013 Jetta Sportwagen 6MT
2013 TDI Sportwagen, owned since new. Got the "fix" some years back at around 64,000 miles. DPF failed shortly afterwards (which is awfully coincidental) but all has been well since then; car currently has 126,600 miles on it. Oh new DPF was covered by the warranty. I have VCDS and the current rate of ash load accumulation is spot on. The Stealership told me the DPF was clogged but a more likely scenario was it cracked.
It threw a CEL, which you could clear but would come back in 25 to 100+ miles. The car ran just fine.
Doing the TB job is WAY beyond my capabilities so farming it out to the VISA wrench, will be using a highly rated indy who specializes in TDI's, old and new.
So the TB service kits have the belt of course and the various rollers/tensioners that should be replaced.
Given all the stuff that has to be removed to do that job; is there other stuff that should be done "while they are in there"?
I had a Mazdaspeed Miata for almost 19 years and the TB service for those cars, they recommended replacing the front main seal. But from what I have read this is not an easy part to access and replace. It's not leaking but beyond 130k it might start; is it worth the money to have this done?
HPFP - mine has been rock solid, car has never been missfueled or any issues with the HPFP.
But it is my understanding it is driven by the TB, and has to be moved out of the way to do the service.
It's a rather expensive part, close to $800....worth replacing "while you are in there?"
I love the car (it's the oh so rare manual, base version) and plan to keep it for a long long time.
Let me know any other things I should consider replacing.
Thanks!
Analogeezer
lemoncurd
PNW
2013 CJAA GTB2266
timing belt and everything it touches. rollers, water pump, tensioner.
throw a new serpentine belt on. you should do that one every 40k, if it fails it can get sucked into the crankshaft cog/gear, and cause the motor to skip timing
leaving the HPFP alone if you havent had any issue's, and the filter has been done every 20k miles. i have 244k miles on my original HPFP, no issues.
at 244k on my 2013, i dont have any leakage from the front seals. though, at my mileage i am considering replacing them while im in there..
for <100k / first t-belt, dont worry about the seals unless theyre damaged / leaking.
Analogeezer
Northern Virginia
Wow great advice, much appreciated. Yes the fuel filters were always changed right on time at 20k. Thanks!
Analogeezer
MrCypherr
Ontario
Mk6 Wagon
I'm getting that new lower timing belt guard on my next TB service. Just to have as cheap insurance. But like said, Just replace all the rollers, water pump, tensioner, belt etc.
Garrison
Charlotte
Stg 3 - 2011 JSW
Well that sounds like a great idea, who makes them/sells them?
Analogeezer
McGuirk
Florida
Audi A3 TDI, 2012 Golf TDI , 2014 GTI to TDI swap
Also a good idea to replace the alternator pulley. You do need a special bit however. Metalnerd sells it on their website. The crankshaft seal is another item you can get replaced since your in that area. Relatively easy.
