Newer revision "Q" part. For 2005-2006 Jetta TDI diesel, engine code BRM, this is the throttle body or Anti Shudder Valve (ASV) . When this valve fails it will cause an engine code and check engine...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
