I had ABS issues so I pulled the fuse. That turned off some warning lights on the speedo, but there is a warning signal in the dash. How easy is it to find and unplug this beeper?
i know if the battery dips below 9v while cranking it will put the cluster into low voltage mode which disables sound output. But unless the whole abs module is bad i would fix the issue. Or just deal with the sounds. I set my cluster to Germany to shut off the door chime and seat belt alarm. But all the other warning chimes still ring-a-ding.
