There seems to be another "running change" on the A4-Jetta gearshift linkage.
Back in late 1998 early 1999 whn the A4 Jetta appeared there were many reports of the rattelling gear leaver in 3rd (mostly). VW released a TSB against this bug and some tinkering was done. My first A4TDI had this problem (minor, compared to its other ailments). My second (60,000 cars later) had a slightly redesigned shifter arrangement on top of the transmission case - the counterweight (for added mass to the throw) for instance was quite different.
I went to the Toronto autoshow today and had a very quick peek under the hood at a TDI there and saw that this whole area is very much redesigned: not only is the "weight" much bigger, but the shifter cables are very different. They appear as if they may have adjustable lengths via knurled knobs. The mechanical arrangement around the selector shaft (comes vertically up out of the gearbox) is larger and possibly more robust. Time did not permit any further more involved investigation, nor did I think to write down the VIN number.
