flan
02J linkage keeps binding up. I took the linkages off and manually exercised them and they freed up, 50 miles later it's stuck in the neutral position again. Anyone ever deal with this?
I think this is the first question. Is it the transmission that "binding up" or is it the shifter cables that are binding up? You need to know exactly where it is getting stuck.Can you shift gears by hand...on top of the transmission?
The cables can be detached from the transmission for testing. If you do this, you might first want to search YouTube for the Dieselgeek video about adjusting your shifter linkage - so you can properly put it back together again. If it is the cables that are binding up, they might have to be replaced. Sometimes they can be lubricated (like WD40) and worked until they don't stick and they will work OK for a while, but this is usually a temporary solution.Seems like the cables are binding up, shifter doesn't want to move.
