There are a couple different straps so some dimensions.and differences in case anyone ever needs a set .
there was two part numbers, one ends in 655F It is 83cm long, stands 18cm tall ,the distance from the front bolt's center to the second pin is 28.6cm and has an oval drain hole at the low point .
the second ends in 656 it is 78cm long,stands 16.5cm tall ,the distance from front bolt's center to the second pin is 26.5cm and has a circular drain hole.https://www.jimellisvwparts.com/products/Volkswagen-VW/Jetta/Strap-Tank-Mount-Fuel/5243858/1J0201656E.html
