Maddawg
So I bought another Jetta TDI. A 01 in decent shape and 290000 kms. Now the fun begins. Gas door and trunk not opening.I pulled the actuator out of gas door and tested . Works fine. Don't hear any attempt of opening either trunk or gas door when using switches or key fob. Fob could have dead batteries. I took door apart and pulled switches. I used my meter on continuity . Single pole on switch to ground and touched other poles while working switch and got the beep. Think I did it right anyway. I tested the plugs for the switches and only got .5 volts while meter was set to 20 which is lowest setting. Tested battery to make sure of setting. I'm assuming there should be 12 volts going to these switches. I went to junk yard and got more switches and plugs for them. Cut 1 ft of wire with them. Don't have a chance to test as I'm away working for the next 4 days. Shouldn't there be 12 volts to plugs even with key off and am I testing correctly as I'm only guessing without a diagram which I would have a hard time reading anyway? Hopefully I'm on the right post also. Thanks and I'm sure I'm not the only one who has had this issue. Looking forward to being on the road again with this Das Auto. Lol
