Fix_Until_Broke
I'm trying to record this sensor on my DAQ system and need to understand fundamentally how it works so I know how to both signal condition and interpret it.
On the surface, it looks like an LVDT, however that's kind of tough with only 3 wires I'm guessing that it's a DVRT, but wondered if anyone has played around with this before?.
My multimeter shows ~2.5vDC on all 3 terminals to ground so that confirms an AC supply & signal I think - guessing that it's 0-5v?
Between Pins 1 & 3 I get:
0.420vAC at idle no accessories on
0.520vAC at idle with all accessories on
This seems like what VCDS is recording/reporting (mine is out on loan right now otherwise I'd verify it myself)
Between Pins 1 & 2 I get:
0.205vAC at idle no accessories on
Between Pins 2 & 3 I get:
0.162vAC at idle no accessories on
0.173vAC at idle no accessories on
Presumably as the core moves it induces a larger AC voltage across pins 1 & 3?
