csstevej
- Joined
- Aug 12, 2004
- Location
- north nj
- TDI
- 2001 golf tdi 4 door auto now a manual, mine, 2000 golf 2 door M/T son's,daughters 98 NB non-TDI 2.0, 2003 TDI NB for next daughter, head repaired and on road,gluten for punishment got another tdi 2001NB,another yellow tdi NB
Trying to find what fuse #37 does/goes to on a 2000 vw TDI manual.
I did a bunch of work on my daughters car the last few days and when my daughter came to get her car , she went to put the radio on and no radio…… went through the fuse panel and found #37 blown……installed a new 10 amp fuse and immediately blew when car turned to the on position.
Fuse #42 seems to be the radio fuse and that’s good.
I didn’t do any work in the car, all work was done for an inoperable a/c , that was a low Freon charge and a broken radiator fan switch wire , an oil change , rear brakes , and slow drivers side window going up……that was just lubing the felt tracks.
I’ve tested everything on the car that I can actuate with a switch or ops test…….everything works except the radio.
Just a side note….the radio was working before i worked on the car, was in it for my test drive with daughter when she showed me her issues.
And where in gods name do you find what fuses does what in the Bentley……..looked but didnt see anything…….
