A Archiejettatdi New member Joined May 3, 2022 Location 77078 TDI Jetta TDI MK4 2002 May 3, 2022 #1 Problems with tightening fuel pump retaining ring
mjydrafter Veteran Member Joined Jul 12, 2015 Location dsm, ia TDI 2004 Jetta Wagon May 3, 2022 #2 I use a huge pair of channel lock pliers. Not to squeeze anything, but because I can open them up and "catch" the ears on the lock ring. Then turn it. It's harder to describe than to do. Every time I mess with one I think it would be easy to make something better.
Nero Morg Top Post Dawg Joined Oct 19, 2017 Location OR TDI 2014 A6 TDI, 2001 Jetta TDI, 2014 Passat TDI May 3, 2022 #3 A flat punch and a hammer also works.
K KrashDH Top Post Dawg Joined Dec 22, 2013 Location Washington TDI 2002 Golf May 3, 2022 #4 Nero Morg said: A flat punch and a hammer also works. Click to expand... This worked great for me. You could also use a flathead screwdriver.
G Genesis Top Post Dawg Joined Feb 26, 2003 Location Sevier County TN TDI '03 Jetta Wagon May 3, 2022 #5 Lubricate the surface where it runs lightly with silicone. Then use a big flat screwdriver and tap on opposite sides. It'll go.
Nero Morg Top Post Dawg Joined Oct 19, 2017 Location OR TDI 2014 A6 TDI, 2001 Jetta TDI, 2014 Passat TDI May 3, 2022 #6 To clarify, not sealing silicone haha Vaseline also works if you don't have lubricating silicone around.
