Fuel pump fuse location
anking
Pittsburgh
2015 Beetle
Does anyone have a fuse diagram for 2015 golf tdi? I need to disconnect in-tank fuel pump so I'm able to connect auxiliary vegetable oil system to see how it will run and have some fun running it on olive oil, etc..
rocky raccoon
Greater metropolitan Beaverdam
2014 Jetta Sportwagen
Not to be a downer but:
Our Diesel engines are designed to run on Diesel fuel. Running any other is sub-optimal and is the road to trouble, expense and heartbreak. One could get away with it on older, simpler Diesels such as the Mercedes W123 but not today's overcomplicated engines such as yours.
and
olive oil is a helluva lot more expensive than Diesel fuel.
anking
Pittsburgh
2015 Beetle
and
I did ask a straight question: where is the fuse. Your unsolicited opinion wasn't necessary and you still didn't answer the question.
Thanks anyways
740GLE
NH
I give it 2 weeks max
"Any top tips on helping me clear some fuel system related codes? I applied logic that can work for a 1950's designed system to my MK7 cause you know diesels are diesels, and now its not happy. Heres a listing of the current codes I have
+17 pages of fuel system related codes"
