Monday,21,September,2020,14:07:40:25594
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: 3VWRT71K25M633740 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K25M633740 Mileage: 372290km-231330miles
00-Steering Angle Sensor -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: VWZ7Z0E1915749
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 6393ABFC275387B32F1-8036
1 Fault Found:
000387 - Fuel Temp. Sensor A (G81)
P0183 - 000 - Open or Short to Plus
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 372295 km
Time Indication: 0
Date: 2000.00.00
Time: 02:05:00
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Temperature: 54.0°C
Temperature: 93.6°C
Temperature: 38.7°C
Readiness: 1 1 0 0 X
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 3A2D3698F059A67B5C7-806E
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6C81C0C0CA8DC8CB9EB-8038
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
000 - -
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000056152
Coding: F4098E02400418000014000000140000002077035C
VCID: 2F3B17CC3B1B73D3FB9-807A
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00000
4 Faults Found:
02395 - Parking Light Front Right (M3)
012 - Electrical Fault in Circuit
02394 - Parking Light Left Front (M1)
01117 - Generator Terminal DF Load Signal
008 - Implausible Signal - Intermittent
01049 - Supply Voltage Term 50
006 - Short to Plus - Intermittent
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD01NPAG
Coding: 0012627
VCID: 2E050AC83C117ADBF0F-807A
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME09187B0AH
Subsystem 3 - Serial number: 6342MSME080E1357A
Subsystem 4 - Serial number: 6351HSME063915090
Subsystem 5 - Serial number: 6361HSME064958134
Subsystem 6 - Serial number: 63727SME06380A3A0
Subsystem 7 - Serial number: 63827SME065A0753/
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 L HW: 1K0 953 549 L
Component: Lenksäulenmodul 013 0040
Coding: 0000041
VCID: 3B23339CFF639F73471-806E
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 971 D
Component: KOMBIINSTRUMENT 3HL 2120
Coding: 0023203
VCID: 2C0100C00A0D08CBDEB-8078
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700105205043C
Coding: 3D3F0B400F1002
VCID: 290FF9D405FF1DE325D-807C
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 HW: 1K5 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 0371356TNSF403
VCID: 78A9EC908ED5746B6A3-802C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 2120
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001271
VCID: 363522A8C441421BB8F-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.2 1502
VCID: 303914B026256C2BE23-8064
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13100F880106281B0906050FA0080F0490A540
Shop #: WSC 09141 444 54011
VCID: 025D8E78D8092EBB447-8056
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 65
Mileage: 372295 km
Time Indication: 0
Date: 2000.00.00
Time: 02:08:12
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001271
VCID: 372B2FACC34BBB13A39-8062
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 A HW: 1K0 035 180 A
Component: Radio DE2 008 0115
Revision: 00008000 Serial number: VWZ4Z7E3030417
Coding: 0040400
VCID: 1E65DA084CB1EA5B40F-804A
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 313F11B42D2F6523EDD-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323D1EB828295E3B947-8066
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D070DC4311701C3C95-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----------(Elapsed Time: 01:07, VBatt start/end: 13.9V/14.0V)-----------
