JSWTDI09
Does anybody here have a dead HPFP lying around? I might just be interested in the fuel metering valve out of it, if you are willing to sell it. Here is the rest of the story:
Last Friday I got an "Emissions Workshop" message in my MFD along with a flashing glow plug light and limp mode. I was only a few blocks from home, so I limped home and scanned my car with VCDS and got the dreaded P0087 - Fuel rail pressure too low. Since the car still ran, I saved the code and reset it. The car ran perfectly. I had a long drive planned for Sunday, so I drove it all over town (over 100 miles) on Saturday. I drove it hard and easy, and I could not get the error to come back. On Sunday, I had to drive to San Diego (over 300 miles) and the car ran fine. Today (Monday) when about 2/3 home (just past Barstow), the glow plug light starts flashing again. As an experiment, I shut off the engine and restarted it (without using VCDS), and got no flashing GP light. I drove the rest of the way home without a problem. When I scanned the car again at home, I was expecting the same thing but got a P0088 instead - Fuel rail pressure too high.
Neither time did the Check Engine light come on. Both occurred at very close to 2000 rpms but under very different circumstances. The first was in second gear going through a very bumpy construction area and the second was cruising at expressway speed in 6th gear. It was about 555 miles between the first fault code and the second occurrence. I intend to replace the fuel filter tomorrow. I just replaced it 2 weeks ago, but I want to make sure I didn't mess up those Olympic rings or anything. It is the last thing I did to the fuel system, so it is worth a try.
Anyway, based partially on this post: http://forums.tdiclub.com/showpost.php?p=4217660&postcount=1
It could be a faulty fuel metering valve. This is why I started this post looking for a dead HPFP. I would also be interested to know if anyone knows of a source or even a part number for this part (VW doesn't sell it). Is there (maybe) any way to service this valve? Any information would be appreciated. If anybody cares, the full fault codes are posted below. I am assuming that the 2 pressure readings are requested and actual pressures.
Have Fun!
Don
Code:
[FONT="] Address 01: Engine Labels: 03L-906-022-CBE.clb[/FONT]
[FONT="]Control Module Part Number: 03L 997 016 N HW: 03L 906 022 J[/FONT]
[FONT="] Component and/or Version: R4 2,0L EDC G000SG 8680[/FONT]
[FONT="] Software Coding: 0050072[/FONT]
[FONT="] Work Shop Code: WSC 00066 000 00000[/FONT]
[FONT="] VCID: 3D7A39A364B1E7C9459-8068[/FONT]
[FONT="]1 Fault Found:[/FONT] [FONT="]Mileage: 80493[/FONT]
[FONT="]000135 - Fuel Rail/System Pressure [/FONT]
[FONT="] P0087 - 000 - Too Low[/FONT]
[FONT="] Freeze Frame:[/FONT]
[FONT="] Fault Status: 01100000[/FONT]
[FONT="] Fault Priority: 2[/FONT]
[FONT="] Fault Frequency: 1[/FONT]
[FONT="] Reset counter: 255[/FONT]
[FONT="] Mileage: 129540 km[/FONT]
[FONT="] Time Indication: 0[/FONT]
[FONT="] Date: 2000.00.00[/FONT]
[FONT="] Time: 12:21:09[/FONT]
[FONT="] RPM: 1978 /min[/FONT]
[FONT="] Inj. Quantity: 9.1 mg/str[/FONT]
[FONT="] (no units): 5.0[/FONT]
[FONT="] Pressure: 640.0 bar[/FONT]
[FONT="] Pressure: 448.0 bar[/FONT]
[FONT="] Temperature: 52.2°C[/FONT]
[FONT="] Tank Cont.: 18.2 l[/FONT]
[FONT="]Readiness: 0 0 0 0 0 [/FONT]
____________________________________________________
[FONT="]1 Fault Found: Mileage: 81048[/FONT]
[FONT="]000136 - Fuel Rail/System Pressure [/FONT]
[FONT="] P0088 - 000 - Too High - Intermittent[/FONT]
[FONT="] Fault Status: 00100000[/FONT]
[FONT="] Mileage: 130437 km[/FONT]
[FONT="] Time: 14:35:52[/FONT]
[FONT="] RPM: 2070 /min[/FONT]
[FONT="] Inj. Quantity: 5.2 mg/str[/FONT]
[FONT="] Pressure: 512.0 bar[/FONT]
[FONT="] Pressure: 760.0 bar[/FONT]
[FONT="] Temperature: 42.3°C[/FONT]
[FONT="] Tank Cont.: 52.9 l[/FONT]
Don
