Pharcyde145
Turbobrick is right, thanks for clarifying! Also great to see you still in the mix after making the transition from Swedespeed.
The ECU that you source from another vehicle will have to be modified via a tune for your car to accept it (if the ECU VIN doesn't match with the info from the CECM still in your vehicle it won't work hence the "immobilizer" function), which is why if you choose to go that route you should keep the ECU that came stock with the car as-is and have the ECU that you sourced elsewhere tuned and the immobilizer deleted and mated to your VIN.
