Dimitri16V
if you like clear hoses you can use those polyurethane hoses made by SMC
http://www.smc.com.cn/webcatalogue/contents/docs/fittings/tubing/tu.pdf
I used the 1065 red colored sized one on the return from the tandem pump to the fuel temp sensor
I had those hoses from work and the stock rubber hose started leaking after I removed it to install another tandem pump. it has hold up fine for a month now with no leaks or softening
