Rob Mayercik
Ok, this was a bit weird:
Was sitting at a traffic light last night on the way home from work. Car was level front-to-back, but tilted slightly to the right, and I'd been sitting stationary for at least 20 seconds. I happened to be looking down at the cluster, and noticed the fuel gauge needle start to "wobble" up and down very slightly.
As that registered in my brain as odd, the darn thing actually jumped up almost all the way to the next hash mark (was at the 1/4 mark, so it jumped up to the 3/8 mark), then proceeded to sink back down and settle about half-way between the two marks, which meant it was reading about 1/16 of a tank higher than it was 5 seconds before.
Since one of my usual fueling points was just up the block after I got the green light and made my turn (was a "no turn on red" intersection), I pulled in and filled up just to be safe as I was about a mile into my 50-mile run home. Car took 13.3 gal fully vented (with trip odo at 565.5 miles), so the gauge reading turned out to be pretty much correct, but I don't think I've ever happened to notice that happening before.
This isn't the car's original sender, but it's been in the car since October 2002. Could this be a sign of a dirty ground, or maybe that the sender might be starting to fail?
