Fuel Filter Change- Fuel Disposal
casteld73
Orange County NY
Jetta '06 TDI
I followed the DYI on the fuel filter change. Worked like a charm. Have a 2006 (fuel filter with two holes). I beleive that is the older version of the filter.
Anyway, One thing I did was use a turkey baster to take out the fuel....now what? How do you dispose of about 10oz of dirty fuel? or is it ok to put back into the tank. Put it in an old washer fluid bottle. Can't say the bottle was completely clean of washer fluid. But there could not have been anymore than an eye dropper worth in it.
What do you guys do?
ps- thread on procedure to change out was excellent.
airwolf
Cassopolis, MI
None
Look for a place the recycles used motor oil near you. Most likely they should take your used fuel. I would not dump it back into the tank if you used an old washer fluid bottle.
Fencemaker
Washington, PA (SW PA)
2006 Jetta TDI 5sp; 2009 JSW TDI 6sp
Yea, I put mine in the farm tractor.
Of course, I don't put the left over fuel from changing the tractor's fuel filter back in the tractor, b/c that stuff is really, really, really dirty. Makes the TDI left over fuel look freshly washed :eek: !
BudsBug
Trenton NJ
2000 New Beetle (Buglet)
I use it to burn the old bank record 10+ in a can they wont burn well without something to keep them going
Burl
Mansfield, TX
2013 Passat TDI SE
I use it to start the BBQ, smoker, burn pile, chiminea, run in the shop heater, spray it to kill weeds, etc.......anything but put it back in the tank and risk contamination.
LF06VWJTDI
Liverpool, NY
06 MkV Jetta TDI
Eeeeh...dunno about that...
I use Startron on a regular basis, that'll keep contamination under control.
sabersix
Sunny San Diego
2010 JSW TDI
First, I wouldn't even bother with the turkey baster. Second, the fuel in the filter canister is not any more dirty than the fuel from the gas station pump, it is just waiting to go through the filter where any dirt is captured.
Put it back in the tank.
jjblbi
lbi, nj
2014 Passat SEL TDI
I don't bother emptying the filter canister, just put in new filter, top off and go. Any residual fuel I had would be mixed with used motor oil and go to the recycling center. JOHN
docvb
Wisconsin
2006 Jetta TDI north sea green, bone stock and loving it!
Hey, any water will be in the bottom of the reservoir. you'd might as well aspirate the bottom inch out to look for water. most won't have water, but if you do have it........you'd want to remove it.
I mix it with waste motor oil as I use my topsider oil change unit to empty the filter housing out. It cleans the bottom crud layer from my tank....
doonboggle
Elgin, Texas
2006 Jetta w/Taktonic 6sp. transmission, Silver; 1981 Rabbit pick-up
This is a "Don't ask ... don't tell" issue...... IMO.
Of course, I live out in the boonies..where among other issues, we can burn our burnable trash items in a burn barrel... or ....
DoctorDawg
Southeastern US
'09 Jetta Loyal Edition
I mix about 2 parts of waste diesel with 1 part used engine oil, and keep it in a sprinkling can (like for watering flowers). It makes a great fire starter for brush piles and the like...the oil gives it some cling when I sprinkle it on the pile, so it doesn't just end up in the dirt. Not explosive like gasoline. I've seen some dumb guys really toast themselves starting fires with gasoline (usually on the third match).
