fuel filler flap frustration
St.Hubbins
Nashville
'10 Golf, DSG / '11 A3, DSG (both went buyback) - '15 GSW SE
FFS, my filler neck is suddenly locked in a closed position... i was able to trickle in a gallon slooooowly to get us home.
is this a matter of disconnecting an actuator or something? i do have VCDS, if i have to open that can o worms.
thanks y'all, it's been awhile :)
USMCFieldMP
Fort Worth, TX
2014 Jetta TDI
JM Popaleetus
Connecticut
Signature.
And now I know what I’m doing tomorrow afternoon. I didn’t realize it could be removed so easily without breaking any tabs.
bigb
Arizona
2015 Sportwagon S
Any chance the station had a small gasoline size nozzle? I heard there are a few diesel pumps out there with the smaller nozzle which won't open the rejection device. I keep one of these in the back for emergency use https://www.youtube.com/watch?v=sA3hrLjdggg
740GLE
NH
Can't believe i'm admitting it, but I can say is it saved me once when i was filling in a morning daze and grabbed the RUG handled and futzed with it not going in and opening. Took about 5 seconds to realize my mistake.
RIP TDI
Santa Barbara, CA
'15 GSW SE 6MT, '01 Golf GLS 5MT, '97 Passat sedan, '96 Passat variant
When you remove the restrictor, don't throw it away; I keep mine in the car so I won't forget where I put it. If you have to go to the dealer for emissions/HPFP warranty work, don't assume they won't check for the presence of the restrictor in an attempt to invalidate your warranty. Its easier to temporarily re-install than remove.
BTW, removal makes seeing when the fuel level is reaching the top of the neck so much easier and I think the best reason for removing it.
adjat84th
Virginia Beach, VA
'01 Jetta TDI/'15 Golf TDI
^^This
I removed mine years ago, but had also already voided any chances at an extended warranty. Keep it around in case you need a warranty claim and enjoy being able to see the fuel/foam when topping up.
JM Popaleetus
Connecticut
Signature.
For sure. That’s why I was pleasantly surprised to see how easy it was to remove. The 2009-2014 retrofit one was a lot more complicated with clips and whatnot.
Dustoff
Cape Cod
2015 Passat SE
I find it a royal pain in the keister. Just bought a 15 Passat TDI and had one hell of a time filling the tank for the first time. I'm considering removing the restrictor however with the 2 year CPO, it's good advice to keep the thing handy. Thanks for the info!
bigb
Arizona
2015 Sportwagon S
What is causing it to be a problem, seeing into the filler neck? I always carry a small flashlight in my pocket and find that all I have to do is lean the nozzle slightly to one side and hold the light there and I can see when the fuel starts to rise up in the filler neck easily, just as easily as my other vehicles without restrictors.
RIP TDI
Santa Barbara, CA
You can see significantly farther down the neck and with greater ease w/ restrictor removed, not to mention the ability to accommodate a larger fill nozzle. Try it; you won't regret it, unless you are using the dealer for regular maintenance and would have to frequently R & R the restrictor. Or if any of the car's anticipated drivers can't be trusted to not mistakenly fill with gas.
uberdiesel
Columbia, SC
2015 Night Blue Golf TDI SEL
Best all
BEST ALLITERATION I’VE EVER SEEN ON FRED’S DIESEL FORUM. HOPE YOU GOT IT FIGURED OUT.
uberdiesel
Columbia, SC
Love the meme. One of the best movies ever.
I meant
noun
  1. the occurrence of the same letter or sound at the beginning of adjacent or closely connected words.
Nuje
Island near Vancouver
2015 Sportwagen; Golf GLS 2003; 2016 A3 e-tron
Ahhh - the quoted text is what threw me off.
And I have 100+ tabs open so didn't see the thread title.
(And yes - Top10 all-time movie for me. :D )
ThatBruceGuy
Ontario, Canada
2015 GSW DSG
^^This
How'd you pull it out?
I've noticed that the Mk7 version is different than the Mk6 filler neck. Couldn't pull mine out with a pick.
JM Popaleetus
Connecticut
Signature.
There are two indents on a ring that you’ll grab with needle nose pliers and then turn CCW to remove.
The flap will then pull right out. Put the ring back in.
