Elfnmagik
I know this is a basic question, but are you guys just using a small funnel w/hose to add the Powerservice before fill up? I bought a bottle over the weekend, but haven't used it since I don't need to fill up yet.
I assume you are being sarcastic here. Of course it's much cheaper per unit to buy in a larger volume, plus it produces less waste (fewer bottles to throw out). Keep at least one empty bottle for measuring and dispensing. That way you can measure the proper amount at home and just dump the whole content in your tank at the gas station.Thunderstruck said:You're right, it's much cheaper to buy one bottle of one shot then get a jug of it and refill from that. A half gallon is only $19.40.
whats wrong with redline water wetter?40X40 said:As long as the fuel additive is rated for ULSD, I would feel comfortable using it in an 09.
Do not use any oil additives, nor coolant additives.
Bill
A ditto, even as I use both Primrose 405 C (1:3000) and PowerServe (1:400) I have NEVER been able to discern from tank full to tank full. (or shall I say when I have either accidently or purposely skipped a treatment) The effect for me has been like throwing salt over the shoulder for good luck: even as I understand both/either/or 1. boosts Cetane ratings 2. provides fuel pump lubricity 3. emulsifies water 4. supposedly boosts mpg by up to 10%. 5. cleans injectors 6. prevents deposits 7. reduces emissions 8. less rust/corrosion 9. etc, etc,Bob_Fout said:I used 32 oz of Opti-lube XPD. Noticed no difference than other additives as far as immediate effects. Its higher lubricity would take many many miles to come to fruition (in terms of lower pump wear).
Used a gallon of XPD. Obviously could not measure any benefits without taking all my shi+ apart.BudEWiser said:Is anyone using this product in their TDI? OPTI-Lube XPD The members at dieselplace.com using the product give it a thumbs up.
http://www.opti-lube.com/XPD.htm - Centurion a division of OutWest Ventures
I'll try contacting them for further information.
I meant I cannot tell the difference between Optilube and other additives (PS, Howes, Redline).ruking said:A ditto, even as I use both Primrose 405 C (1:3000) and PowerServe (1:400) I have NEVER been able to discern from tank full to tank full. (or shall I say when I have either accidently or purposely skipped a treatment) The effect for me has been like throwing salt over the shoulder for good luck: even as I understand both/either/or 1. boosts Cetane ratings 2. provides fuel pump lubricity 3. emulsifies water 4. supposedly boosts mpg by up to 10%. 5. cleans injectors 6. prevents deposits 7. reduces emissions 8. less rust/corrosion 9. etc, etc,
cures baldness- hey maybe that is why I am not bald.
Yep, VW does not recommend any additives for there '09/10 TDIs. Good enough reason for me.scott_o said:Anyone else using Opti-Lube XPD in their '09 TDIs? I've found tons of people on internet forums who use it in their diesel trucks and love it, but haven't found as many TDI drivers.
I was hoping to hear of more people experiences with it (or other additives) in their '09s. Any reason I shouldn't order a gallon of the stuff? Opinions?
Not exactly correct. VW does allow up to 5% bio. 2% bio works better as a lubricity additive than anything tested (google 'spicer diesel report'). 1 liter/quart bio per fill is approx. 2%. As an additive used like this, it cost practically nothing.GTIDan said:Yep, VW does not recommend any additives for there '09/10 TDIs. Good enough reason for me.![]()
So, does that mean to put 1 quart of 100% Bio (B100), or 1 quart of 2% Bio (B2) per tank. I know nothing about biodiesel, hence the question.barshnik said:Not exactly correct. VW does allow up to 5% bio. 2% bio works better as a lubricity additive than anything tested (google 'spicer diesel report'). 1 liter/quart bio per fill is approx. 2%. As an additive used like this, it cost practically nothing.
John F
'09 JSW TDi
1 qt of B100. You don't have to know anything about biodiesel for this one--it's simple math my friend. Let's say a fill up is 14 gallons, 4 qts in a gallon. So that's 56 qts. 1/56= ~1.8% concentration of bio. B2 into straight D2 is nearly B0, lol.scott_o said:So, does that mean to put 1 quart of 100% Bio (B100), or 1 quart of 2% Bio (B2) per tank. I know nothing about biodiesel, hence the question.
I used 1 gallon of Optilube XPD--I just couldn't justify the cost. Powerservice is less than half the cost. I figured at the end of the TDI's useful life I wouldn't be able to measure the difference anyway. The cam will probably die before anything fuel related...securityguy said:GTIDan - the lubricity of ULSD fuel is poor at best. You should use something to help your HPFP work efficiently. I have been using PS since my very first tank and just switched to Opti-Lube based on the lab study that was posted. It hasn't arrived yet but I look forward to using it based on what many folks have said and the results of the wear testing.
