What is the difference between Diesel Fuel Supplement +Cetane Boost and Diesel Kleen +Cetane Boost?
Diesel Fuel Supplement +Cetane Boost (in the white bottle) is a winterizer/antigel for use when temperatures drop below 30°F. for winter operability. Diesel Kleen +Cetane Boost (in the silver bottle) is an injector cleaner and performance improver for use when temperatures are above 30°F. Use our seasonal tip to help remember which product to use: “White for winter, silver for summer.”
Can I use Diesel Fuel Supplement +Cetane Boost and Diesel Kleen +Cetane Boost at the same time?
Yes, we have many customers that do not want to lose the performance improvements provided by Diesel Kleen +Cetane Boost when the weather gets cold. The products are compatible and can be used together.
How often should I use Power Service diesel additives?
Our recommended Year-Round Maintenance Schedule is:
Every time you fill up:
If temperatures are above 30°F, add Diesel Kleen +Cetane Boost (silver bottle) for maximum performance. This Max HP Formula is loaded with cetane, detergent and lubricity improver to provide peak diesel performance.
If temperatures are below 30°F, add Diesel Fuel Supplement +Cetane Boost (white bottle) for winter operability. This Arctic Formula will prevent fuel gelling and protect against fuel-filter icing.
Will it hurt my engine to use Diesel Fuel Supplement +Cetane Boost year-round, even though it contains an antigel for winter operability?
No, it will not hurt your engine to use Diesel Fuel Supplement +Cetane Boost (in the white bottle) year-round. However, for maximum performance we recommend using Diesel Kleen +Cetane Boost (in the silver bottle) when temperatures are above 30°F. (Use our seasonal tip to remember: white for winter and silver for summer.)
