FS: VIN Unlocked Kerma Q-pro 2x tunes $400
jhax
Golden, CO
96 Passat B4V, ALH engine out of a 2002 Jetta, some IE Rods and ASV Pistons. Nothing drivable yet though
Hello fellow enthusiasts. I am listing my Q pro for sale, the vin is unlocked and it includes two tunes. This was for my ALH, 11mm IP, gtc1549vz (24psi), dlc1019 nozzles. I would like to get $400 for the tuner and two tunes.
Cheers,
Justin
jhax
Golden, CO
I didn't have it on the car long enough to do any dynoing, I drove the car for 2500 miles with the tune, still breaking it in. I am not following what you mean about the immobilizer. The ECU that the tune was on I had immobilized separately.
jhax
Golden, CO
Bump
Mozambiquer
Versailles Missouri
Just so you know, the tunes won't work for another vehicle. You'd only be buying the tuner, then you'd have to buy tunes from kerma.
jhax
Golden, CO
Unless your ALH is similarly set up to mine. VNT17, dlc 1019 nozzles, 11mm injection pump
Mozambiquer
Versailles Missouri
But the tunes are locked to the original VIN, right? Which is what I think Mozam was referring to.
Yup, that's what I'm pretty sure they do.
jhax
Golden, CO
jhax
Golden, CO
The vin is no longer locked as can be seen by the photo.
jhax
Golden, CO
I loaded the original tune back on my car which unlocked the vin.
ebbnflow
NOR CAL
2003 Jetta GLS TDI
The tunes are locked to your vin and will not work for another vehicle. The unlocked loader will work for another vehicle but the tunes will not.
