FS: parting out a 1z from a 1996 passat
Cmolloy444
El Monte
Alh swapped datsun 720 4x4
Hi, I have a 1z that snapped a timing belt, selling as individual parts or complete. The belt failed because the intermediate shaft pulley came loose and then misaligned, so the shaft and pulley are damaged. 292k miles on the motor when it failed. Injection pump is throwing an injection quantity code. Turbo is good, and I have most of the accesories as well as a complete wiring harness and ecu. Let me know if you are interested in any parts, I am located in the east LA area and I can ship things if needed.
samuraitd
Provo, UT
ahu mtdi samurai swap, 1991 jetta ecodiesel
How much are you looking to get for the whole engine, harness etc?
Cmolloy444
El Monte
The engine is missing the alternator, power steering pump and bracket, injection pump bracket, timing covers and harmonic ballancer. How about $300 for everything, less if I remove more parts
97TDIGUYYY
Dekalb, Texas
1997 Volkswagen Jetta 1.9L Turbo Diesel
How much for the wiring harness, ECU, part number 3A0 919 506 Engine cooling fan relay switch, and the coolant plug relay module. Can send pictures if necessary!
wvoaction
Baltimore, MD
MK4 BEW, T3 syncro AHU
Do you still have the alternator/compressor bracket? If so, how much and shipping to Maryland 21227? Thanks!
