drew19973
I have a full CR140 engine out of a 2012 Jetta that was totaled after a rollover. Car had 73k miles on it at the time.
Reason for parting out is the wiring harness was damaged and the car would not start after the accident. Easier to partout than prove that it runs well.
EVERYTHING is for sale (except the EGR Valve, pending) so make me an offer. DPF was ruined while taking the engine out (the guy sawzalled it in half...
) but everything else is there.
Cylinder head includes cams and valves, no injectors or fuel rail. Block includes rotating assembly.
Clutch and flywheel/starter are also for sale, along with the 02Q transmission.
If you see something you want just let me know and make me an offer. Worst I can say is no
Price list:
Block - $500 w/ rotating assembly
Injectors - $300 for set (Pending)
Head - $600 w/ cams, follower, valve cover
Fuel rail - $100 w/ fuel lines (Pending)
EGR valve - $125
EGR cooler - $75
Turbo - Sold
Alternator - $50 w/ pulley (Pending)
AC Compressor - $100 with pulley (Pending)
HPFP - $300 (Pending)
Starter & flywheel - $300 (Pending)
ECU - $250 (for CJAA with a manual transmission)
Trans - $600 (Pending)
Price list:
EGR valve - $125
EGR cooler - $75
Turbo - Sold
