FS - complete part out of 2002 Black Jetta ALH
BehroMoto
Rockford, MI
2002 Jetta, Silver | 2001 Golf, Black | 1998 Beetle, Blue
2002 black exterior / grey and black two-tone interior
She had 250,000 miles on her.
Ran great - anything that was bad or needed significant work is not for sale here.
Most parts priced includes shipping. Large or heavy parts may be additional for shipping costs - let's talk about it.
PM or post in you're interested in anything.
Mike Behrens (BehroMoto)
___________________________________________
Long block ALH Engine (block, head, valve cover, water pump Timing belt, tensioner, both timing belt covers) compression of 510 on all 4 cylinders. [I would replace timing belt, water pump and tentioner while you have it out of the car, though) No oil pan. 850
ALH Auto to Manual Swap Complete Package SOLD 850
Engine Area:
Radiator 40
Power steering pump reservoir SOLD 15
Power steering pump w/ pulley 45
Turbo VNT-15 (solid bearing w/ no axial or end play movement) SOLD 200
Injection pump 300
Serp Belt tensioner 35
Intercooler 100
Question mark hose 40
Lower intercooler hose (the one with the with "pancake" tube) 40
Upper intercooler pipe 40
Alternator SOLD 55
Intake manifold - professionally pre cleaned 75
Battery Duracel 920 CCA (1.5 years old) SOLD 40
Coolant reservoir 20
A/C compressor w/clutch 80
A/C condenser 35
Fan control module 30
Injector hard lines (set) 55
Air box and hose 50
Radiator (only two years old - idparts) 50
ECU 130
Vacuum pump 40
Alternator/AC Bracket (cast aluminum) SOLD 45
Fuel lines from filter to injection pump 35
Battery tray 20
MAF 35
Coolant glow plug housing 25
N-75 Valve 40
N-18 Valve 25
Anti-shudder Valve 25
EGR 40
Vacuum tank 15
Oil cooler housing 25
Interior:
Leather interior - front and rear seats (grey) (one wear mark on driver bolster) 150
Blower resistor pack (new - 1 year old) 30
Glove box (gray) SOLD 50
Door panels (black & gray) (all) 120
Instrument cluster 50
Driver seat belt 25
Passenger seat belt 25
Body/Frame:
Air bag (drivers side) 35
Air bag (passenger side) 35
Fuel tank (Diesel) 90
Fuel sending unit 35
Wiper mechanism (1 year old) (with motor) 75
Front H-Sub Frame 85
Fuel door (black) 25
Parking brake cables (newer larger diameter) (both) SOLD 25
Trunk lid (black) SOLD 50
Door Front Driver (black) (small quarter-sized bent corner easy to fix) 50
Door - Front Passenger (black) 50
Door - Rear Driver (black) (one scratch across that would need to be fixed) 50
Door - Rear Passenger (black) 50
Head lights (each) SOLD 25
Tail lights (driver side) SOLD 20
Tail light (passenger SOLD 20
Hood latch mechanism 25
Hood latch support 20
Trunk liner (original carpet) (great condition) 40
Wheel liner - front driver 25
Wheel liner - rear driver 25
Wheel liner - rear passenger 25
Windshield washer reservoir and pump 50
Front bumper cover brackets SOLD 10
Front bumper (steel) 50
Rear bumper (steel) 50
Rear bumper cover - including metal and plastic body brackets (black plastic) SOLD 60
Grille (black) SOLD 25
Grille emblem 25
Wiper arms (each) 20
Roof to door seal - driver side 25
Roof to door seal - passenger side 25
Front anti-sway bar 50
Cowl cover (plastic) 50
Cowl seal (under hood) 25
Radiator fan SOLD 35
Steering/Suspension
Control arms (both) 40
Rear axle beam SOLD 90
Rear springs VR6 - rusty, but only 3 years old (both) 30
Steering rack SOLD 90
Steering knuckle - driver side (bearings not bad, but I would replace it)) 60
Steering knuckle - passenger side (bearing not bad - but I would replace it) 60
Steering column (with turn signals) no steering wheel 50
Brakes
Front driver caliper 35
Front passenger caliper 35
Rear driver caliper SOLD 35
Rear passenger caliper 35
Rear caliper bracket 25
Parking brake cables SOLD 20
JDSwan87
Black Swamp Thing
Michigan near Toledo
2001 Jetta TDI, 5 speed Lagoon Blue Metallic(sold); 2005 Jetta TDI Wagon auto
Pics of seats? Specifically drivers side since those see the most wear...
BehroMoto
Rockford, MI
PM'ed you.
Rub/wear marks on the driver side bolster. (Where they all wear from getting into the car.)
Here's the pics for anybody else who wants to see them.
