Ookpic
I'm selling my pristine BBS RXII 2-piece wheels with custom paint. I'm asking $1800 for the entire package or best offer. I have no idea what this package is worth. This is how I worked out the rough price...
$600CAD for the tires purchased in Canada.
$700USD for the wheels purchased years ago
$200USD for the spacer/lugs.
$600CAD for the custom paint.
Wheels:
I dis-assembled these wheels very carefully marking each wheel so that they would go back together the exact same way as they came apart. The wheels were then sent to my wheel guy who striped them and painted them. These wheels had no damage on them before the paint! These wheels have never seen winter or salt. 2 of these wheels balanced out perfect with no weights. I'm unsure what the offset is on these but they will 100% fit on any mk4.
Size - 16" X 6.5"
Bolt Pattern - 5 X 100mm
The Paint:
The wheels are painted with a custom 4-stage paint process. After the wheels were striped, they got epoxy primed, then base coat satin black. I purchased paint that is imported from Italy that is a transparent silver paint. The wheels have 2 coats of the transparent silver paint on them. The final stage is clear coat. A couple of the wheels have 1 small chip in the paint. I've attached close-ups. These chips are less than 2mm in diameter not sure if these are stone chips or if I've accidentally hit them with the socket. I didn't even notice until today when I washed them.
The Center Caps:
I purchased a complete set of Black BBS center caps as well I have the original VW center caps that will come with the package. The VW caps have a bit of peeling on the outer plastic.
The Tires:
The wheels will come with Continental Extreme Contact DW Tires. These tires are virtually brand new. I bought them last summer and drove them until fall then took them off for the winter. They have less than 10k kms on them for sure!
The Spacers:
Wheels will come with custom CNC machined 20mm spacers. These are hub and wheel centric spacers made by 42Draft Designs. They will also come with lugs that are properly sized.
Wheels:
Size - 16" X 6.5"
The Paint:
The Center Caps:
The Tires:
The Spacers:
