czar
Thanks! It is on eBay but if someone from here is serious, pm me as I'd rather make a nice donation to Fred's than pay eBay.
I have this completely unsubstantiated theory that when you put words such as amazing, unbelievable, incredible etc. in the description of a vehicle, you multiply the selling time by a factor of 2 or more.tdidieselbobny said:I can't believe it took this long-hopefully this time it pans out for you czar....
Thanks for the info. I am also amazed about the time it took for this to be sold. As I was reading this thread about the car I had two different ideas about this car. The first one was that there is something wrong and no one is speaking about it. I have read all the threads and posts about this vehicle. This vehicle has a forum history.TornadoRed said:Rob, IMO you bought a pretty good car. You got a good deal, too. I still can't believe it was offered for sale in October 2008 and took 15 months to find the right buyer.
Just take care of it, fix whatever needs fixing when it needs fixing, and you can expect to put another 300k+ miles on it.
There may be folks out there who spent as much money or more for cars that don't run and will need $3k-$4k more just to get them running.
From your location in New Jersey, there are at least 3 or 4 reliable TDI pros within a couple hours. So for anything that's TDI-specific, like a turbo or injection pump issue, or when it needs a new timing belt, or any low-power troubleshooting, don't let some local yahoo work on it. Take it to a pro and it will save you money and hair follicles.
I'm not sure about a special tool; VAG-COM is used to monitor the AT fluid temperature, which apparently expands and contracts with changes in temperature. The main thing is that however much AT fluid you take out, put at least that much back in, and maybe just a little bit more for good measure.98NYFINESTVETTE said:I read that there is a special tool needed to change the trans fluid on the automatics. I plan on doing all the work myself.
The only negative thing I have read about a TDI is the automatic transmissions are or could be a weak link. I am hoping I still have some life left in this one with 211,xxx miles on it.
I thought I read someone where that there was a special tool to fill the transmission. I am also reading so much at one time that my brain could be going into a melt down.TornadoRed said:I'm not sure about a special tool; VAG-COM is used to monitor the AT fluid temperature, which apparently expands and contracts with changes in temperature. The main thing is that however much AT fluid you take out, put at least that much back in, and maybe just a little bit more for good measure.
If your transmission ever fails, for the price you paid it will make good sense to replace it with either a professionally rebuilt one or else converting to a 5-speed manual (which would be my choice). It might cost as much as $4000, but it will be worth it. You would still end up with an excellent car for under $8000, good for another couple hundred thousand miles.
Thanks for the Dealer info. I read that in every post. Regardless of the subject or the thread, it was always stay away from the dealer. That is ashame that the dealer is not able to do the work or do the work properly. That is my next thisng to do on my list - Locate a VW tech and also a VW Trans Tech. I would hope to see this car run to over 300,000 miles. This would take 10 years to reach.tdidieselbobny said:There also is a guy in the midwest that FIXES the 01m's I believe in case your's ever decides to fail (some reason I think his forum name is CoolAirVW) -might want to do a search for that name and see if it is.Be nice to have someone on speed dial just in case. Oh yeah,BTW, if you can't tell by the threads on here,AVOID THE DEALER!!!!! Find the nearest guru to you-may be a few hour drive,but they are well worth it and better than dealer. Congrats on the purchase!
You were probably thinking of the new DSG automatics -- they require a special tool (plus Vag-Com), because the new fluid is gravity-fed in through the drain hole.98NYFINESTVETTE said:I thought I read someone where that there was a special tool to fill the transmission. I am also reading so much at one time that my brain could be going into a melt down.
That may be a fuel cooler -- some TDIs have them, some do not.98NYFINESTVETTE said:I did notice what appeared to be the trans cooler under the right floor board. It was a quick glance due to the outside temp is 20 degrees.
You are correct about that. I saved the info and read it again. Just as you said - gravity fed to fill trans. Thanks for the info.frugality said:You were probably thinking of the new DSG automatics -- they require a special tool (plus Vag-Com), because the new fluid is gravity-fed in through the drain hole.
Hopefully this week will be in the high 30's. I will then be going through the car inside and out.TornadoRed said:That may be a fuel cooler -- some TDIs have them, some do not.
