Looking for the lower headlight brackets, inner front fender liners, grommet around antenna base, front side marker lamps any plastic covers/shields under the front of the car possibly all 4 struts and springs and possibly shifter boot and knob. Just bought a mk3 jetta gas and it's been "pa dubbered" I'm looking to return it to stock and usable
I have the block, pistons, rods, flywheel, balancer, head, transmission, intercooler, a/c compressor, starter, airbox, battery tray, glove box, and other smaller bits. For now, I still have the car, still with alot of parts, but will be going to the scrap yard. Let me know what you need.
Hi, Still parting out a 98 jetta with an AHU engine . The car had 140k on it. Here is a list of parts I still have along with some others I had laying around. If you don't see what you need, pm me. However most of the major items have been sold. These prices don't include shipping. Thanks
Cylinder head. $300
Flywheel. $75
Harmonic balancer. $40
4 pistons. $125
4 connecting rods. $125
Motor mounts $30 each
Innercooler with pipes. sold
Air box. $50
Airbox to turbo pipe. $30
Pulleys. $15 each
Valve cover. $15
Oil pan. $20
Battery tray. $25
Mass air flow sensor. $30
Coolant flanges. $10 each
glow plug heater flange w/ gp. $30
Fuse block. $30
Glove box/ no key. $35*
Center console. $40
A list of Other items I had laying around not from the jetta
T-15 turbo core. $30
Injector pump core. $75
96 passat air bags, cover, controller and steering wheel. $75
98 jetta instrument cluster w/200k on the odometer. $25
I'm not 100% sure of the miles on that odometer
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
