FS 97 Passat TDI 1z part-out (MI)
1997 Part out of a 97 Passat 1Z TDI (similar to ahu). Car care was well documented and well cared for. Car has 270k miles and was getting quite rusty, so my son and I decided to part it out. Before disassembling the car I video taped the compression tests on all four cylinders and all were between 490 - 500 psi. The cylinder walls are in good shape with only a very minor lip at the top. The car has always used Shell Rotella synthetic and I have documentation of every oil change since October of 2000 when it was sold from father to son. I will mark SOLD behind items as they are sold. I couldn't list every item, so feel free to ask about any of them.
Engine Related or Engine bay:
All prices include shipping within the lower 48 states unless other specified.
- shortblock = $800 plus shipping
- transmission = $300 plus shipping
- injection pump = $300 plus shipping
- injector hard lines = $65
- altern/Inj Pump bracket (cast iron) = $80
- downpipe (was repaired at one point) = $45
- turbo outlet pipe (alum) = $40
- harmonic balancer = $25
- access belt tensioner & roller = $35
- vacuum pump = $45
- PS pump = $35
- PS reservoir = $15
- PS brackets = $25
- clutch slave cylinder = $20
- egr gas cooler & both pipes = $40
- metal backing plate behind TB = $20
- coolant reservoir = $20
- coolant housing = $15
- coolant housing at t-stat = $15
- pulleys (pw steering pump, water pump, crankshaft, intermediate shaft(SOLD)) = $15 each
- camshaft gear = $20
- battery tray = $20
- upper TB cover plastic = $20
- N-75 valve = $40
- coolant glow plugs/housing = $20
- IC piping (plastic) = $70
- cylinder head = $300 plus shipping SOLD
- turbo SOLD
- altern/AC bracket (cast alum) = $50
- Rear seat belts - SOLD
- alternator = $75 (120 amp) SOLD
- cabin air filter frame- Sold
- Driver door hinge - Sold
- Oil filter bracket - SOLD
- radiator w/ aux fans = $70 plus shipping SOLD
- batt cable (pos) = $15 SOLD
- Hubcaps - SOLD
- intake manifold $60 SOLD
- turbo drain line = $30 - SOLD
- complete set of injectors = $130 SOLD
- lines from filter to IP - SOLD
- ECU = $135 SOLD
- engine wiring harness (complete and uncut) = $185 SOLD
- turbo inlet pipe (plastic) = $15 SOLD
- intercooler = $50 SOLD
- fuel sending unit = $40 SOLD
- AC compressor/clutch = $80 - SOLD
- starter = $75 SOLD
- air box flex tube = $15 SOLD
- air box SOLD
- batt cable (neg) = $15 SOLD
- fuel lines from filter to IP = $35 SOLD
- lower TB cover plastic = $20 SOLD
- MAF = $50
- glow plug control module - SOLD
- oil cooler - SOLD
Body Related:
(doors & fenders are pretty rusty and hood has a dent. Driver seat has bolster sag, but other than that all seats are in good shape. Most interior pieces are in great shape.)
- airbag (pass side) = $30
- airbag (steering wheel) = $30
- lower radiator support = $40 plus shipping
- master cylinder = $40
- mirror (silver) drivers side = $25
- spare tire = $20 plus shipping
- emergency jack = $15 plus shipping
- windshield washer pump = $10
- door panels very good shape = $25 each plus shipping
- taillights sections $20 ea.
- headlights $15 ea.
- rack and pinion steering - $50 plus shipping
- rear disc dust shields SOLD
- visors SOLD
-emergency brake handle SOLD
- drive shafts - $65 each plus shipping
rear brake calipers - SOLD
- pedal cluster = $75 plus shipping
starter/engine mount/tranny mount bracket - SOLD
clock spring - SOLD
rear view mirror - SOLD
- mirror (silver) pass side = $25
- exterior door handles = $15 each (all worked well) SOLD
- instrument cluster = $75 SOLD
- 4 sail panels - SOLD
- 3rd brake light light strip - SOLD
- Front cup holder - SOLD
- Rear cup holder and ash tray - SOLD
- Shifter Knob - SOLD
Lots of other parts including black interior pieces, brackets, etc.
(WANT PICS? - pm me your # or email)
- Doug & Ben
- vacuum pump = $45
- PS pump = $35
- PS brackets = $25
- N-75 valve = $40
- turbo SOLD
- Hubcaps - SOLD
- ECU = $135 SOLD
- air box SOLD
- MAF = $50
- oil cooler - SOLD
Body Related:
- visors SOLD
clock spring - SOLD
- Doug & Ben
