FS 2004 Jetta TDI GLS - Connecticut
mshubey14
Connecticut
2004 PD Jetta TDI - 157K
Well it's become time to sell my beloved 2004 Platinum Grey Jetta TDI GLS. This has been a great car for me. I purchased the car on here 6 years ago with 124k miles. I am the second owner of the vehicle. It just turned over 203k miles. I have upgraded just about everything on this car. Bigger turbo, injectors, exhaust, stage 4+ rocket chip tune, etc. This car is quick and still running strong! It is clean inside and out. Here is a list of mods that were done to this car, most of them by tdi guro Mike Hevner.
17/22 turbo, r783 Injectors, Euroject FMIC, RC4+, Chrome-Plated Stage II Titan Cam, SBC Stage 2 Endurance Clutch, 17" Monte Carlos, 3" SS Turbo Back Exhaust including dp, DG Panzer Plate FMJ, TT Short Shifter and Pedals, PD150 Engine Cover, PD150 Intake Manifold, Koni FSD's with Bilstein shock (car is lowered by about 2"). Boost gauge
Here are the maintenance records that I have kept:
Timing belt was changed out at 135K miles
Turbo was installed at about 145K miles - 17/22 hybrid
Clutch was changed out at about 135K miles
Cam shaft was installed at about 145K miles
Brakes with rear rotars 170K
3/9/14 - 180,600 miles
Changed the oil and filter - Liqui Moly Diesel High Tech 5w40 505.01 was used
Changed fuel filter
Changed cabin air filter
Air filter was not needed because it was changed out about 1000 miles ago.
3/15/14 181,000 miles
Changed the suspension - Installed Koni FSD's with new Bilstein shocks
New cubra rear axle bushings installed
Alignment
New nitto tires
Changed out starter.
Installed stiffer dog bone mount
8/9/14 - 185,900 miles
Oil change
Charged battery
Warranty replaced front rotors
Replaced crankshaft position sensor
November 2014 - 189,000 miles
Changed to snow tires.
March 2015 - 192,000
Bought winter rims and tires from friend
6/13/15 - 195,000 miles
Changed fuel filter
Changed air filter
Purchased new key fab
Put summer tires back on
I did change the oil and filters many times before 180k just didn't know the dates or mileage.
Main reason I need to sell the car is because I'm changing jobs and will be commuting 1 hour to work. I want to get a bigger more comfortable car to ride in for 2 hours a day. I wanted to put it on here before I went to craigslist.
Asking price is $6,000. I will have pictures up shortly/this weekend.
Thank you for your interest. Please PM if you have any questions.
-Mike
mshubey14
Connecticut
