CalvinM
Unfortunately, I need to sell my Golf due to immigration/covid reasons. I've put quite a bit of work into it after buying it from the original owner here on TDIclub two years ago. I had planned to keep it for quite some time.
Here is the previous for sale thread when I bought it:
Highlights:
5 speed
E code headlights with fogs
ESP and heated seats
Sunroof
Well kept interior and exterior
Factory rubber floor mats
Since purchasing it:
Mileage to 298k
Timing belt & bosch alternator @ 295k
LUK 17-050 DMF clutch, synchromesh, and rear main @ 290k
Bluetooth head unit seen here https://forums.tdiclub.com/index.ph...adio-for-double-din-style.502950/post-5546287
Evolution imports atlas skid plate
.216 injectors @ 298k
Turbo actuator
All motor mounts
bosal oem replacement downpipe and cat
serpentine belt and tensioner
coolant bottle
multiple other small things as well.
will come with fresh oil change and filters(oil, fuel, cabin, and air)
the bad:
Valve cover has a slight leak. I've tried to reseal with dirko but in the end it will probably need a new cover
small fender bender to right rear that was repaired locally by 1st class auto body in bellingham. They did an excellent job.
I stored the original wheels and tires so those will go back on for sale. Like new ohtsu tires.
$3k firm. Car will be located in Portland for the next couple weeks then Bellingham after that.
2003 Golf GLS 5 speed - original owner - NW Washington
*** SOLD *** $3,000 276,000 miles. No accidents, clean, no rust. Runs strong and mileage has consistently been 42 - 44 mpg (750 miles per tank). Maintenance done on schedule. Only synthetic oils used: mainly Rotella T6 but also Mobil 1 TDT and 0w40. Only German brand filters used. Timing belt...
forums.tdiclub.com
Highlights:
5 speed
Sunroof
Mileage to 298k
Turbo actuator
All motor mounts
coolant bottle
the bad:
