robnitro
FS: ALH parts BROOKLYN, NY area
Parts for sale (mailing priority mail)
Rims for sale (locally, pick up)
<s>Car sold</s>
Click to see bigger version of thumbnails.
--Ecodes with fog lights. currently on car but easy to swap stock back in and sell car with those, but shipping may cost too much?
--almost new MAF bosch 0281 002 757. ALH stock maf. The maf on the car turned out to be ok. It was a plug issue so I put back stock maf. 50+ship
--Pancake pipe Better than stock skinny one- lower turbo to IC Pancake pipe with a boost tap which I used for dawes device back then
You can flip your clip to connect to VNT17 and use a hose clamp onto this one $20
--VNT15 worked fine when taken off a few years ago. The actuator arm was welded on because I was working vanes loose and it became very sloppy. No play and no damage. $100
--another VNT17 dead bearing/ scraped housing , and the exhaust to downpipe manifold it's on has one stud cut . Useable for a core or a rebuild. Make offerSOLD
--ABS pump 1C0 907 379 C $50
--Stock Upper IC pipe, with 2 taps capped.$20 was repaired when ps pulley rubbed it. found the correct epoxy and its very strong, trust me
--Stock turbo intake pipe, (from maf flex to turbo intake) $20
--egr cooler clean, stock egr setup $50 OBO
--stock EGR with asv both functional $20
--stealth stock egr, has asv but egr is epoxied closed $20
--10mm pump +lines (worked fine when swapped to 11mm but a bit noisy)- $200 obo
-- Bosio Sprint 502 (.216) nozzles, SOLD
--Stock .184 bosch nozzles, SOLD
--2 sets of avus rims
Local please- one set clean, other curb rash
--1 set of steelies
--1 set of avus like design, but not avus. Has curb rash. Is currently on the car.
Rims negotiable for local convinient sale
--new oil filters mehle 6 of them (updated), prefer together. 25 +ship
--new air filters mann, 2 of them, prefer together, 10+ship
THE CAR IS SOLD, ONLY PARTS AVAILABLE ARE LISTED ABOVE
<s>Car sold</s>
--1 set of steelies
