WOB Long
Parting out entire car, so if you are interested in a specific part just message me.
I will update post with a pictures folder soon.
Car has a clean title, so would entertain selling the entire car minus the long beaches. Buyer would need their own rims to purchase. Would not come with an engine . Engine transmission is already taken out of the car.
Black leather gti seats 150
Leather rear bench 50
Leather door cards set 200
Sold
02J 5speed transmission w/speed sensor
Sachs vr6/G60 clutch kit 038198132H (1k break in miles on it) comes with new flywheel bolts
Sold
Manual transmission swap parts 300 obo
Transmission mounting bolts
Drop down transmission mount w/bolts
Clutch pedal and bracket w/nuts
Clutch master cylinder line
Clutch start disconnect switch w/pigtail
Clutch cruise disconnect switch w/pigtail
Clutch slave cylinder
Clutch slave cylinder line w/retaining clip
Brake pedal and bracket w/nuts
Brake cruise disconnect switch w/pigtail
Brake and clutch mount nuts(9)
Starter (rusty)
Starter bolts (2)
Transmission to motor mount brace and bolts
RH and LH axles (not oem)
Axle bolts(12) and retainers(6)
Early Shifter assembly w/cables
Shifter assembly mounting bolts
Flywheel dust cover w/access plate and bolt
PS Line
Reverse switch plug w/pigtail
Also have 2 alh heads as cores.
100 each OBO
One was a blown head gasket.
One ate a retainer/valve spring on piston 1.
( I can also break them down and sell cam,lifters, valves etc.
Link to Facebook marketplace
Sold
Sold
Starter (rusty)
Starter bolts (2)
PS Line
100 each OBO
