FS: 02M Race Clutch and Flywheel
arne487
Fort Collins, CO
'03 Golf TDI, '10 TDI Cup Jetta
Not really sure what any of this is worth, so please let me know if I'm way off on prices. Everything is priced before shipping, but I'll ship anywhere. Photos are linked and I'm happy to take more if requested.
Clutchmasters FX600 725 Series Clutch and Flywheel $200:
02M 6-speed only. Dual disc (sintered and organic) friction materials. 28 pounds combined weight of clutch and flywheel. The pressure plate is cracked and needs to be replaced. I would probably replace the organic disc as well, but it would certainly run fine as-is. This clutch is aggressive, hard to drive and squeals a bit because of the sintered disc, but it will hold anything you can throw at it.
SOLD Ported ALH Head $175 SOLD
Aggressively ported and clearanced for a massive lift camshaft. On one cylinder, the bore that the valve guide goes into is slightly too big. Someone with decent machining skill could probably sleeve it or build up new material and re-bore it or something. I don't need/want your core.
SOLD BFI Stage 2 Engine and Transmission Mounts $80 SOLD
Top mounts were installed for a few weeks and removed because they were too aggressive for me. The bottom mount was left in a bit longer, but the rubber is holding up well despite it being pretty dirty.
SOLD VE Camshaft $150 SOLD
256/256 11mm "TDIMeister" camshaft. Not a drop in; requires machining to the head for fitment. Excellent condition. I don't need/want your core.
SOLD Darkside Tubular Exhaust Manifold $200 SOLD
8v GTB manifold as seen at this link. This was a first-batch manifold, which I believe was 304 stainless vs. 316. This does have the threaded port at the collector for an EGT probe. Be aware, there is part of a bolt broken off in the downpipe flange which I'm not going to spend the effort removing for you.
bubs526
Illinois
None
Ok for the motor mounts what year car are they for I have 2001 Jetta manual transmission will they work for my car?
arne487
Fort Collins, CO
They should fit any manual Golf/Jetta/New Beetle between 1999 and 2003. If your Jetta is a TDI, they will fit.
This is the compatibility list from BFI:
1999.5-2005 VW Golf & Jetta with 1.8T, 2.0l or TDI engine
1998-2005 VW New Beetle 1.8T or 2.0l engine
This is the current version of the same mounts:
arne487
Fort Collins, CO
I dropped the prices on what's remaining. Surely someone has a use for this stuff cluttering up my garage.
fatmobile
north iowa
Who did the porting on the head?
I've heard it needs to be done right on the intakes.
All the valves for it included?
The rest of the valve guides installed, except for the wallowed hole?
arne487
Fort Collins, CO
The thread linked below is the information I have on the porting of the head. I don't have the name of the actual machine shop that did the work. Pretty sure I have the valves, lifters and dual springs and can include them, but I can't guarantee any of that is usable. The guides are all removed and if you want them for some reason I have them as well.
