BlueCTTDi
OK, So I was having a rough day last week and I figured what better therapy than to drive around for a bit with the radio off and wind out the engine a bit and listen to the wonderful sound...
And it was great.. until I started going over a few bumps..
seems that BOTH front springs are creaking so badly it sounds like a brass band. It's really only been noticeable for the last week or so. I can replicate the noise even just going out and pushing down on each front corner. Call me an idiot maybe, but last I knew that was a sure sign that they're on the way out. rebound doesn't seem to be too bad (i.e. once down, once up - doesn't seem to indicate a shock issue), but I have to admit I'm not an expert on suspension components. The front end still seems pretty tight, alignment is still ok, and a quick look doesn't indicate anything broken.
I've made no modifications except for putting R32 wheels on the front end (direct bolt-on, no spacers), as well as installing a panzer plate, both of which occurred at about 33,000 miles back in late March. I can't imagine that these two items would alter things enough to wear out stock springs in the span of 4,000 miles.
I know that some folks have had early problems with the stock vw suspension, but at 37,000 miles??? I could understand if I drove the car that hard, but I'm actually pretty good with it.
This kind of noise normal on the mkiv's, or should I be concerned about the springs failing?
