PickleRick
- Joined
- Nov 29, 2017
- Location
- Greenville sc
- TDI
- 05 GLS BHW sedan 5 speed conversion. BHW Carver SantaCruz in progress
It's common knowledge these control arm bushings can be problematic with cracking/tearing which cause an awesome clunk noise when shifting gears or going over bumps. It can also cause alignment and wondering steering going down the free way.
I run a shop, a lawn equipment shop so im essentially a lawn mower mechanic, i don't have a bill gates budget to throw into my daily driver beater car.
This leaves the 400 to 600+dollar (sometimes double these prices depending on source) oem or o.e. replacement front end contol arms out. I looked at the HD meyle kits but even their reviews left much to be desired with premature tears despite proper install. I have spare sets to drive on while exchanges are being made but if i pay top dollar i want to be 100% sure ill have a worry free install.
I found a set for 175, all 8 front arms. The manufacturer varies depending on current inventory. Seems to be the case for many of our vw suppliers.
This distributor offers 10 yr warranty against torn bushings and loose ball joints or any failure not caused by abuse. Bend them in half running off the road and you're on your own.
Even if i have to replaced them every 2 years it's a good deal in my opinion. My biggest issue is the bolt in the rear control arm by the rear subframe is a pain.
I don't like messing with the subframe as this is an issue to many to get a competent alignment. If oilhammer was closer id have him aligning it but I've yet to find a local shop willing to touch it.
So the pita bolt...what ive found is if you turn it around, put the nut on the outside you don't have to lower the subframe again to change the control arm. Less 45 min a side to do uppers and lowers. This includes beer sipping breaks or "coffee shop" breaks for you hippies in Colorado.
How i install control arms.
Measure center hub to your wheel well. Remember this or write it dowm. Then jack up car, remove wheel, replace all control arms. I torque all ball joints snug. I finger tighten the bushings.
I then lower the car with a jack and put the weight of the vehicle on the hub im working with on a large wood block. I then measure to see if the center hub to wheel well are the same distance as if it was still on the tire. A binding parking brake can cause it to be too high, be careful with this as you dont want it rolling off your block if you have to release it to ease the binding.
I then examine all control arm bushings to see that they are all netural and not binding. If they are good i then torque them all down using a dab or blue loctite as i don't believe in one time use bolts on 99% of suspension components. I antisieze all thru bolts and upper ball joints. Lower ball joints i clean the thru holes out with spray brake cleaner and air. I wipe the ball joint shafts with brake cleaner on rag to ensure no grease for maximum friction on install. Once jacked back up i double check all torque specs. If a torque wrench wont fit i just torque until if feels right based on bolt diameter.
I used to use factory specs for control arm distances however friends/family/ my personal vehicles are all usually lifted or lowered and that really throws this spec off. I suck at math thanks to my south Carolina public education so i like to leave the guess how low or high i am compared to stock plus spring settling calculations out of it. Adjustable coil springs are the very worst! Then add in adjustable control arms...its no wonder so many shops dont touch modded suspensions.
Not sure if anyone else uses this method, has worked great for me for a few decades and other than an energy suspension kit for a honda civic which was very ill fitting i have never had an issue with oddly worn tires/alignments or prematurely worn bushings/ball joints. Other than large lifted off road vehicles i have a tire shop do my alignments, 12 inch and wider mud tires that dont travel over 50 have more leeway where you can align them with straight edges and a tape measure. Our cars need more precision.
I cant remember who else it was on here that kept having clanking over bumps and or shifting but I'd gambell its his control arm bushings. I worked for weeks trying to find the source of mine. I had to remove rhe shock to release the load on my lower control arms before i could feel the play in it. I put some used ones in from a parts passat to make sure this was my only issue and the clunking went about 90% away unless down shifting aggressively in the cold. These were still worn so i didn't expect like new results, used will only bandaid rhe situation and with worn uppers i highly doubt they will live long as i need to do all of them at the same time.
Let me know how you guys (looking at you oil hammer) torque your control arms.
