RES
- Joined
- Sep 21, 1999
- Location
- TRUMBULL,CT. USA
- TDI
- 2000 Jetta TDI, 1997 Passat (Totaled in Accident) 2010 Jetta Sportwagon TDI
I just leave mine on both top and bottom until it is warm enough outside to not need it. If you are driving along and think your car is over heating it takes less than 1 min to remove. No pre planning needed.
Roger that... I will post them here later this week.It definitely would be interesting to see the coolant and intake temps with the temps in the 70s.
I too have seen a nice increase in mpg with the IDParts covers in place...back to near summer levels!
Is held on by Velcro strips. Velcro go's around the grill slats and the cover is fastened to the Velcro on lower grill. Upper grill has some sticky tape with Velcro on other side. This secures the upper part. The lower part has a piece that fits in snug between the 2 lower slats (snug fit). Works pretty good.I just became aware of the existence of this product; looks to be backordered at iD parts.
How does it attach/detach to the grill(s).
I've had two instances of IC icing, the first one was really my fault
(I left the car idling for an extended period of time in ~30 degree weather (not trying to warm it up, I was moving cars around and then discovered my wife's MINI had lit up the TPMS so rather than shut my JSW off I left it idling in the cul-de-sac.....BAD MOVE),
the second one was not my fault.
I like the idea of regaining a bit of mileage too.
We get pretty wide weather swings here though, can be 20 degrees one day and 60 the next, so being able to attach/detach these quickly sounds like a plus.
Thanks!
Analogeezer
I've used all covers upper and lower since I got them with no problems with air flow to the intake. Seen a few passive and active regens of the DPF also. All is good.While removing the top cover on the driver side today, I noticed that the engine air intake inlet is somewhat blocked by fabric of the top cover. Apparently it is not a problem since no one is complaining, but it does seem to block the flow somewhat. I am wondering if it would be a good idea to remove part of the air inlet and divert the intake to the inside of the engine compartment if you are going to use the top cover.
Look at the back of the air box that the inlet feeds, it is open. No problems blocking that inlet.While removing the top cover on the driver side today, I noticed that the engine air intake inlet is somewhat blocked by fabric of the top cover. Apparently it is not a problem since no one is complaining, but it does seem to block the flow somewhat. I am wondering if it would be a good idea to remove part of the air inlet and divert the intake to the inside of the engine compartment if you are going to use the top cover.
+1 on this!I've used all covers upper and lower since I got them with no problems with air flow to the intake. Seen a few passive and active regens of the DPF also. All is good.
I think that once the car is moving that the wind will cause the bit that is partially blocking the intake to flatten out and allow air to enter. Even if it did totally block the air intake air will still enter from the backside.While removing the top cover on the driver side today, I noticed that the engine air intake inlet is somewhat blocked by fabric of the top cover. Apparently it is not a problem since no one is complaining, but it does seem to block the flow somewhat. I am wondering if it would be a good idea to remove part of the air inlet and divert the intake to the inside of the engine compartment if you are going to use the top cover.
Thanks interesting, I did not realize that the airbox was open in the rear. I wonder why people bother to take the box off completely to get engine compartment air when all you have to do is tape up the front.Look at the back of the air box that the inlet feeds, it is open. No problems blocking that inlet.
Got a 46.8 mpg this tank over 620+ miles... very happy to see summer time economy with the front grille blocked & the airbox sucking in hot air...
