its normalpossibly. Best way to diagnose a bad shock is to get that corner of the car bouncing by pushing up and down on that fender. then let go. A properly functioning shock should bounce once and then stop. A bad shock will bounce up and down several more times.
all ok visually nothing looseHave you checked the front roll bar bushing and link? LCA? Upper mount?
nope not that either.Jack the car up at that wheel and grab the tire at 9 and 3 and try to wiggle it side to side. And try again at 12 and 6. A bad ball joint will cause movement and can cause the sound you're talking about.
