Front fender liners
jakesnaketdi
Charlotte, North Carolina
2014 JSW
Alright fellow enthusiasts, had something wild happen on the highway. 2014 Jetta Sportwagen- I'm not sure if I lost something but a piece of plastic came flying off and hit the drivers door. I pull over and the front black air dam is dragging on the ground and both front fender liners were completely rubbed through from my tires. I'm trying to pull up pics of the undercarriage but is it just the large belly pan and then the front black air dam and fender liners? I already had the belly pan off as I'm getting ready to delete the DPF. Lucky the whole front bumper didn't get ripped off.
Are you asking a question? Or just making a statement? Because it is quite common for many low-sitting modern cars (not just Volkswagens) to get their undersides damaged from all sorts of things.
That car should use two piece front fender liners. Then there is a flat piece that goes from the bottom of the bumper cover back to the bottom of the lock carrier assembly.
DivineChaos
Minnesota
mk6 jetta sportwagen tdi
Post pictures or explain it better. There's an under black lip on the bumper cover. The engine splash shield. Outer splash Sheilds, fender liners, and the 2 long underbody pieces. What's missing?
